I have used AddHotPictureTag to add a bitmap to a TRichViewEdit.
I then use SaveHTMLToStreamEx to create HTML.
I want the set the HTML Alt text for the bitmap presumably using rvespAlt but how do I do it?
Regards
Thomas Davenport
rvespAlt
rvespAlt
Hello Sergey,
I know I am being stupid but when I use the code you sent Delphi returns
[Error] Gash5P.pas(120): Undeclared identifier: 'vespAlt'
I have RVItems in the uses clause at the top but I cannot see how to access the extra properties.
Regards
Thomas Davenport
Regards
Thomas Davenport
