I use the method "InsertStringTag" to insert fields. It works great.
Is there a method to insert strings with RC (#13#10) ?
Yann
InsertStringTag with RC
No, sorry. Because it's rarely needed.
You can use this procedure (assuming that rvoTagsArePChars in rve.Options):
If you use TRichView version older than 1.9.22, remove calls to BeginUpdate and EndUpdate.
Update 2011-Oct-22: changed for compatibility with TRichView 13.3+
procedure InsertTextTag(rve: TCustomRichViewEdit; const Text, Tag: String);
var SL: TStringList;
i: Integer;
SL := TStringList.Create;
SL.Text := Text;
rve.BeginUpdate;
for i := 0 to SL.ItemCount-1 do
rve.InsertStringTag(SL[i], Tag);
// for older versions of TRichView: rve.InsertStringTag(SL[i], Integer(StrNew(PChar(Tag))));
rve.EndUpdate;
SL.Free;
