We insert TCheckBox controls into our templates. We just notice they do not showup in TSRichViewEdit. They are very important to us and we will have to revert back to TRichViewEdit.
I'll send you an example.
I tried it with you Actions Test and it has same problem.
Note that you have to RegisterClasses([TCheckBox]) in initialization. I did that in actions test and it still did not show the check boxes.
TCheckBoxse not showing
Estimated date?
This is very important to us. Do you have an estimated date?
Re: Estimated date?
The problem with Controls is solved. I the next couple of days we'll upload the update v1.2.8.
Re: Estimated date?
See update v1.2.8.
TCheckBox still not showing in latest ScaleRichView
I recently upgraded since it seemed issues we has were fixed in srv but I just discovered my existing rvf files don't show TCheckBox. I tried the actionTest demos, added RegisterClasses(TCheckbox). Regular richview works great but srv does not show the cb fields..
Problem solved!
I was registering both TSRVCheckbox and TSRVCheckbox. I removed TSRVCheckbox and it now shows checkboxes on existing docs.
