Addict Spell Check problems
jimmaguire
Post by jimmaguire »
I can't get addict live spell check to work with TSRichViewEdit. Works fine with TRichViewEdit. I tried to get it to work in your ActionTest, checked each area you have commented, but no luck.
When I call the RVAddictSpell3.CheckRichViewEdit(srve.RichViewEdit, ctAll), it gets into ad3SpellBase.ContinueCheck ok, but FParsingEnding.NextWord returns nothing each time so I just get "Spelling check is complete".
I've tried using the OnSpellingCheck event, but it causes a gpf before the form loads.
We will check this problem.
jimmaguire
Solved problem - it still may be an issue with TSRichViewEdi
I deleted the uncommented OnSpellingCheck which I noticed was actually for RichViewEdit, not SR... in actions test and created a new one and then no longer got gpf. The new OnSpellingCheck of SRichViewEdit does not get called when I call rvActionAddictSpell31.
So then I assigned the OnSpellingCheck event in code during my form's create event and that did it, it now works. I stepped into the ScrlRView code and can see the assignment of the OnSpellingCheck event, but it does not take for some reason.
I just placed RVAddictSpell31 : TRVAddictSpell3 on the form and added a button with the code:
RVAddictSpell31.CheckRichViewEdit(SRichViewEdit1.RichViewEdit, ctAll);
It works as expected.
jimmaguire
It was just the OnSpellingCheck that I ended up have problems with, and just when I created the event via design. I've got everything working now, just assign the event in code. I started with the actiontest example as my base, maybe something got messed up in the translation. OK now!
proxy3d
ScaleRichView Developer
Re: Thanks
Post by proxy3d »
The problem with OnSpellingCheck event will be fixed in the next update ScaleRichView v1.2.7
proxy3d
Re: Thanks
Post by proxy3d »
ScaleRichView is updated to v1.2.7. Must be ok now.
jimmaguire
StartLiveSpelling waits until 1st key stroke
I use Addict, but the red lines don't show until I press a key. Here's the code:
rvActionOpen1.LoadFile(srve.RichViewEdit, FileName, ffiRVF,0);
srve.RichViewEdit.StartLiveSpelling;
This code works for RichViewEdit in another form, but not TSRichViewEdit.
I'm using 1.2.7
Livespelling is not implemented by 100% in ScaleRichView.
It works, but red underlines appear only on next repainting of SRichViewEdit.
It will be fixed sooner or later.
JonRobertson
Post by JonRobertson »
Sergey Tkachenko wrote:Livespelling is not implemented by 100% in ScaleRichView.
The demo still does this. Was this ever fixed?
In the current version, live spelling check is completely implemented in ScaleRichView.
However, there may be some problem with starting live spelling.
First, live spelling check in SRichViewEdit starts when you load a document, because in the latest version SRichVeiwEdit.Format calls OnChange. It will be fixed in the next update. Currently, a quick fix is assigning SRichViewEdit.RichViewEdit.LiveSpellingMode = rvlspManualStart.
Next, if you call SRichViewEdit.RichViewEdit.StartLiveSpelling immediately after loading a document, live spelling check is not start. This is a bug (if StartLiveSpelling is called immediately after an editing operation that started live spelling, it fails), It will be fixed as well. A quick fix is the same.
Camphausen
Demo for ScaleRichView, Addict 4.3 and Delphi XE2
Post by Camphausen »
I have just upgraded to SRichView 5, RV 14, and Addictive Spellchecking 4.3.
Is there a demo available? please!
Christoph
Sorry, we do not have a demo for Addict 4 and ScaleRichView.
However, it can be easily created using ActionTest demos.
The instructions can be found here:
http://www.trichview.com/help-actions/addict_3.htm
They explain how to use Addict 4 with RichViewActions and TRichViewEdit. But for TSRichViewEdit, the instructions are almost exactly the same.
The ActionTest demos have the code working with Addict4 commented. Search for "Addict" in the source code of the main form unit.
