Corrupted file
jimmaguire
Corrupted file
Post by jimmaguire »
I've been using TRichViewEdit for a couple years with no problem. We are beta testing the same program using ScaleRichView and had a case where TRichViewEdit.LoadRVFFromStream complained that the file was corrupted or in use. Sure enough, the blob field it was stored in had only a few lines that were unreadable except where one had "style". Note that the blob field is now written to using TSRichViewEdit.SaveRVFToStream, but other parts of the program that do the mail merge still use TRichViewEdit.LoadRVFFromStream.
Anyway, my question is, where should I look. Thanks!
jimmaguire
Ignore above post
It must have been something with out db, the blob field magically reappeared? Not a TSRichViewEdit problem, sorry. :{
jimmaguire
Was due to incompatiblity with cell padding
This problem turned out to be due to an incompatibility where older versions of trichviewedit cannot read rvf files saved by new versions when the cell left and right padding is not equal. I had the problem even when the padding is the same so I ifdef out the code as suggested in the bugreports forum.
proxy3d
ScaleRichView Developer
Re: Was due to incompatiblity with cell padding
Post by proxy3d »
This question on a component trichviewedit. Please write here only questions concerning ScaleRichView.
Questions concerning TRichView at forum RichVew.
