Matching margins/pages to a pdf
I use IIPDFLib to create PDF's and I am having a problem where the pdf has page breaks and margins different from either the richviewedit print preview or the new ScaleRichView. I switched to ScaleRichView hoping it would match the pdf more closely, and it does, but still has differences.
I can send an example where ScaleRichView shows the document as one page, but it shows the pdf generated via IIPDFLib in Acrobat Reader as two pages.
I know you do not support IIPDFLib, but I believe the problem may be that I have to first create an RTF before it will create the PDF.
Would switching to TRichViewPDF match what ScaleRichView shows more exactly? Any other suggestions? Thanks!
demo for pdf
Can you create a demo for using the gnostice libs....This is the only thing holding me back in converting my app to this new scalerichview.
Kind Regards.
Kind Regards.
Great news...thanks
Will check daily
This demo creates PDF files in WYSIWYG mode using LLPDFLib ( http://www.llion.net ):
<URL IS REMOVED> (source code only)
Update: this demo is included in the main set of demos for ScaleRichView
Last edited by Sergey Tkachenko on Mon Aug 20, 2007 9:29 am, edited 1 time in total.
Demo won't compile - srve.DrawPage - undeclared identifier
Waiting for reply, can't find DrawPage anywhere
Thanks!
Thanks so much! Works fantastic, much faster than going to a rtf first and most importantly, the pdf looks just like the rvf!
Left border of table gets trimmed from pdf
The left border of a table gets trimmed from pdf if its left justified. I get around this problem by centering tables that are used as layout templates for our documents.
Not a huge problem, since centering solves it.
Sent examples
I sent the email to you and to [email protected]. I sent to his email address I got when I bought the package, but it was returned. Is there another address I should use besides the proxy?
Re: Sent examples
I have received your two letters on [email protected]
