Mix CSS with normal HTML
cychia
Post by cychia »
There are some formatting which are not support by normal non css html like for example, indent and text background color. In this case, does RV has such a feature to allow save mix html. Example when I call Rv.SaveHTML, the exported HTML will be in normal non css html, but for some those formatting that i mentioned above like indent, it will be saved as inline css.
Sorry, there is no such option, and it's not planned.
The only possibility is using CSS for non-text items, include rvsoForceNonTextCSS in the Options parameter of SaveHTML.
