about LoadRVFFromstream
dutboy
Post by dutboy »
sir:
I use LoadRVFFromStream method to insert content from anthoer RichViewedit. The code is here:
  RichViewEdit1.Clear;
    bs:=TMemoryStream.Create;
    richviewedit2.SaveRVFToStream(bs,false);
    bs.Position:=0;
    RichViewEdit1.LoadRVFFromStream(bs);
    RichViewEdit1.Format;
  bs.Free;
These code work well when richviewedit2's content doesn't contain Hyperlink.
If in richviededit2's content, I insert one hyperlink(using Richviewaction), one error then occur. Error code like this "...... is not valid integer value".
How can I resovle this question ?
Thank you.
It happens because RichViewEdit2 contains items having strings in tags (the most probably they are hyperlink targets).
Include rvoTagsArePChars in RichViewEdit1.Options
