Error when using InsertRTFFromStreamEd
queeniekwan
Post by queeniekwan »
  RtfStream := TStringStream.Create('abc');
    RtfStream.Seek(0, soFromBeginning);
    IsLoadSuccess := RichViewEdit1.InsertRTFFromStreamEd(RtfStream);
    RtfStream.Free;
I am a Delphi programmer and now using Delphi7 and 1.9.15.1 version of RichView.
Coding shown above works fine when Style of RichViewEdit1 is set to a RVStyle and the unicode property of all TextStyle of that RVStyle were set to False.
However, there is EListError when run "InsertRTFFromStreamEd" if I set the unicode property of all TextStyle of that RVStyle to True. The error message is: "List index out of bound(0)"
'abc' is not a valid RTF content, so it normal that RTF inserting fails.
queeniekwan
But I can insert 'abc' by using InsertRTFFromStreamEd if unicode property of all TextStyle of RVStyle are set to False.
Do you mean that I cannot insert non-RTF content if unicode property of all TextStyle of RVStyle are set to True?
Actually, it should not be inserted in all cases, both if Unicode=True and if Unicode=False.
But ok, I made change allowing to load plain text content by this method even for Unicode styles. It will be included in the next TRichView update.
queeniekwan
Thank you!
Uploaded
