list in tablecell ??
Stef
Post by Stef »
Untill now I thought that each cell in a table could only contain a normal paragraph or a list.
If you're editing in a tablecell, and after typing some normal text, you enter a list, then the normal text above also changes in a list format.
But if you type an empty line after the normal paragraph, you can insert a list safely, without changing the text above in list style.
Could I be doing something wrong or is it just a feature ?
thanks,
There should be no difference in lists inside and outside tables.
Please give me step-by-step instructions how to reproduce this problem.
Stef
Post by Stef »
sorry Sergey,
my fault !!
lists in table do behave the same as outside tables.
The phenomena appeared in the previous version of my program ;-)
(too much has changed since, so it has no meaning looking for what I was doing wrong)
cheers,
