Save rvhtmlimport in stringrid
edossa
Post by edossa »
hello
I load in richviwedit a page web with rvhtmlimport, as I can make in order to save some data that serve to me in one stringrid?
thanks
sorry my english
Do you load document by rvhtmlimporter from some string? Why not to use this string to assign to the stringgrid cell? I do not remember if it supports multiline text, though.
edossa
Post by edossa »
I read a page web with rvhtmlimporter and from richview I would want to save it or in an Array or a stringgrid. thanks
Use richview.SaveHtmlToStream or SaveToStreamEx to save document to TStringStream.
edossa
Post by edossa »
Hello sergey you can makes an example me as I must make in order to pass all one stringrid?
var table: TRVTableItemInfo;
MS: TMemoryStream;
ms:=TMemoryStream.Create;
Memo1.Lines.LoadfromFile('F:\\dati.html');
RvHtmlImporter1.LoadHtml(memo1.Text);
ms.SaveToStream(ms);
ms.Position:=0;
rvesource.LoadTextFromStream(ms,0,0,false);
rvesource.Format;
thanks
Sorry, I do not undestand your code.
What does ms.SaveToStream(ms) mean?
Do you want to load HTML source code in rvesource and set it to stringgrid? Why not to use StringGrid.Cells[0,0] := memo1.Text?
edossa
Post by edossa »
Hello excuse for my English, is not explained to me well. I load a page web in Richview and must capture some data as I can capture them (no source html) and put them in a database or stringgrid or string? thanks
edossa
As I understand, you need to load HTML in TRichView, save this document as text, assign this text to StringGrid cell.
This code assumes that RvHtmlImporter1.RichView = rveSource.
uses RVGetText;
  FileStream: TFileStream;
  StringStream: TStringStream;
  // 1. Loading file
  FileStream := TFileStream.Create('F:\\dati.html', fmOpenRead);
  StringStream := TStringStream.Create('');
  StringStream.CopyFrom(FileStream, 0);
  FileStream.Free;
  RvHtmlImporter1.LoadHtml(StringStream.DataString);
  StringStream.Free;
  rveSource.Format; // not necessary if you do not need to display HTML in rveSource
  // 2. Getting text
  StringStream.Cells[0,0] := GetAllText(rveSource);
edossa
Post by edossa »
Sergey thanks
Richview is divided from many cells? can be copied one cells x,y?
how I make in order to copy only some data that interest to me?
example:
12:00 CET Friendlies Indonesia - Jamaica 2-1
12:00
CET
Friendlies
Indonesia
Jamaica
2-1
Do you want to copy TRichView table to TStringGrid?
edossa
Post by edossa »
I want copy only some data of RichView to stringgrid. Exists a way in order to make it? RichView is supplied of cells?
banal example:
dato:string;
dato:=richview.cell[1,10];
stringgrid.cells[1,1]:=dato;
or in other way with same result.
thanks and sorry for the problem.
edossa
I can make an example, but I do not understand how do you want to define part of document to copy.
There is no "richview.cell[1,10]", because TRichView does not have cells. It may include table with cells, probably several tables with cells.
If you want to get text representation of table cell, use
dato:=GetRVDataText(table.Cells[1,10].GetRVData);
GetRVDataText is defined in RVGetText unit.
edossa
Post by edossa »
ok but for being able to copy the text in table column for column?
