Hi!
I use TRVReportHelper in my project and when I insert an image into a header or footer, the size of image is about 5 times smaller then original size. On the printer the size is correct, the problem is only in print preview.
The example of my problem is in the project here: http://pogocki.waw.pl/smaller_footer_images.zip
Where is the problem - in my source code, or in RV?
Thanx in advance
JP
Why TRVReportHelper wrongly resizes images on print preview?
The following things must be changed:
1) Add PrnCanvas: TCanvas to the form's private variables.
2) Change these procedures to use PrnCanvas:
3) In TForm1.RVPrint1PagePrepaint, use PrnCanvas as the first parameter of rvhHeader.Init and rvhFooter.Init.
{ Menu: Print preview }
procedure TForm1.Preview1Click(Sender: TObject);
var DC: HDC;
DC := RV_GetPrinterDC; // from PtblRV unit
PrnCanvas := TCanvas.Create;
PrnCanvas.Handle := DC;
PrnCanvas.Font.PixelsPerInch := GetDeviceCaps(DC, LOGPIXELSY);
FormatDoc(PrnCanvas);
Preview(PrnCanvas);
PrnCanvas.Handle := 0;
DeleteDC(DC);
{ Menu: Print }
procedure TForm1.Print1Click(Sender: TObject);
var DC: HDC;
Print;
DeleteDC(DC);
