Change picture to hot-picture when resizing ?
Stef
Post by Stef »
For html pages you often include large pictures,
which are shown smaller in the document,
and when you click on it, you get the picture in full size.
It would be nice when you make a (large) picture smaller,
that the picture would change automatically to a hot picture
(linked to the orginal picture location).
Is this possible ?
thanks,
No, you need to do it yourself.
But usually HTML pages includes not a scaled large picture but a smaller version of picture.
Stef
Post by Stef »
1.
ok, I'll do it myself,
is there some event, when a picture is resized with the mouse cursor ?
2.
Apperently I expressed myself wrong,
because that's exactly what I mean ;-)
thanks,[/quote]
Sorry, there is no such event.
If you want to convert scaled pictures automatically, I think it's better to do it for all pictures in the document just before HTML saving.
Stef
Post by Stef »
I used the onSaveItemToFile event,
and the implementation (shown below) is very straight forward.
It only adds hotspot information if image is resized.
cheers,
procedure Tform_rve_edit.RVESaveItemToFile(Sender: TCustomRichView;
const Path: String; RVData: TCustomRVData; ItemNo: Integer;
SaveFormat: TRVSaveFormat; Unicode: Boolean; var OutStr: String;
var DoDefault: Boolean);
filnam :string;
gr :tgraphic;
s :string;
tag :integer;
Valign :trvValign;
w,h :integer;
if (RVData.GetItemStyle(ItemNo)=rvsPicture) or
(RVData.GetItemStyle(ItemNo)=rvsHOTpicture) then
if SaveFormat=rvsfHTML then
TCustomRichViewEdit(Sender).GetPictureInfo(ItemNo,filnam,gr,VAlign,Tag);
filnam:=ExtractRelativePath(This_Filename,filnam);
TCustomRichViewEdit(Sender).GetItemExtraIntProperty(ItemNo,rvePimagewidth,w);
TCustomRichViewEdit(Sender).GetItemExtraIntProperty(ItemNo,rvePimageheight,h);
if (gr.Width<>w) or (gr.Height<>h) then
outstr:='<a href="'+filnam+'">'+
'<img width='+inttostr(w)+' height='+inttostr(h)+
' alt=""'+
' src="'+filnam+'"></a>';
dodefault:=false;
Stef
Post by Stef »
terrible layout :-(
is there a way to improve that,
or isn't it even allowed to post code snippets ?
cheers,
Select the text and press Code button.
Text between [code] and [/code] is formated using monospaced font.
Stef
Post by Stef »
ok, new try
  filnam :string;
  gr     :tgraphic;
  s      :string;
  tag    :integer;
  Valign :trvValign;
  w,h    :integer;
                ' alt=""'+
        dodefault:=false;
Stef
Post by Stef »
Correction:
everywhere where "TCustomRichViewEdit(Sender)" is used,
this should be replaced by "RVData",
otherwise it goes wrong if images are in tables.
cheers,
Stef
Post by Stef »
Correction2:
This shouldn't be done of course with a hotpicture ;-)
