Overwrite font of a range when inserting tags
Toni Santa
Post by Toni Santa »
I've a style (FieldStyle) with ModifyProtect = true; when inserting 'Fields' (InsertStringTag..) this style is applied first (CurTextStyleNo = noFieldStyle). Now I would have the need that the inserted 'tags' (fields) are automatically formatted with the same font as it has the position (range) where I'm inserting. How can this be applied without loosing the 'FieldStyle' of the inserted tag?
best regards
Toni
You cannot, because text style defines all font properties.
But you can create protected style with the desired attributes:
function GetProtectedStyle(RVStyle: TRVStyle; StyleNo: Integer): Integer;
var TextStyle: TFontInfo;
    TextStyle.Assign(RVStyle.TextStyles[StyleNo]);
    TextStyle.Protection := [rvprModifyProtect {,rvprDoNotAutoSwitch}];
    Result := RVStyle.TextStyles.FindSuchStyle(StyleNo, TextStyle, RVAllFontInfoProperties);
    if Result<0 then begin
      RVStyle.TextStyles.Add;
      Result := RVStyle.TextStyles.Count-1;
      RVStyle.TextStyles[Result].Assign(TextStyle);
      RVStyle.TextStyles[Result].Standard := False;
    TextStyle.Free;
OldStyleNo := rve.CurTextStyleNo;
rve.CurTextStyleNo := GetProtectedStyle(rve.Style, OldStyleNo);
rve.InsertStringTag(...);
rve.CurTextStyleNo := OldStyleNo;
