Cancel Loading RTF
topcat
Cancel Loading RTF
Post by topcat »
When an RTF is loaded from a memorystream is it possible to cancel the progress during loading. How do I do this safely?
The reason I ask is because I have a dialog box containing a cancel button which displays when an RTF file is loading. I would like the cancel button to stop the loading process.
Thanks for your time!
I did not think about it... But I believe calling Abort in OnProgress must work.
topcat
Post by topcat »
I used the following to cancel loading rtf:
rtfAbort : boolean=False; // global var
cancel button event:
rtfAbort := True;
in the OnProgress event for trichview:
if rtfAbort then
Richeditview1.clear;
Abort;
