RTF via TDBRichView
felisca
RTF via TDBRichView
Post by felisca »
Hey,
I have used TRichView->LoadRTF(with path to RTF).
Now I want to use TDBRichView and to get path that stored as string in TClientDataSet .
DataField in TDBRichView throws error if I set string field.
What can I do?
What type is DataField in TDBRichView?
P.S. I need it to be autoedit.
I do not understand the question completely, but as for data type for TDBRichView/TDBRichViewEdit, it must be able to contain data of any size.
(Table.FieldByName(...) is TBLOBField) must be True for this field.
If field contains RTF document, it may be a memo field.
But by default, TDBRichViewEdit stores documents in RVF, not RTF (you can change this by modifying FieldFormat property). For RVF documents, the field must be able to store arbitrary binary data.
felisca
Post by felisca »
I will clarify the question.
I have field that is String type and contains path to RTF file.
Can I load it to TDBRichView without changing String type field to Memo type?
No, TDBRichView assumes that it is linked to TBlobField.
After conversion to memo, you can use LoadCustomFormat event to display RTF files linked from this field:
procedure TForm1.DBRichView1LoadCustomFormat(Sender: TCustomRichView;
  Stream: TStream; var DoDefault: Boolean);
var s: String;
  Stream.Position := 0;
  SetLength(s, Stream.Size);
  Stream.ReadBuffer(PChar(s)^, Length(s));
  Sender.LoadRTF(s);
  DoDefault := False;
felisca
Post by felisca »
And how can I convert RVF to Binary?
Sorry, what do you mean?
