Pictures in an RTF files
topcat
Post by topcat »
I am using the following code to open RTF file from a memory stream:
      RichViewedit1.Clear;
      RichViewedit1.LoadRTFFromStream(MyStream);
      RichViewEdit1.Format;
The RTF files that I am opening contain pictures. I have noticed that by default the pictures are not scaled to 100% (original size).
Is there an option to automatically scale all pictures in an RTF file to 100% prior to being displayed to the user?
Thanks for your time
[/code]
Do you want to ignore picture scaling specified in RTF and display all pictures in their original size?
Use the following procedure:
procedure ResetPicSize(RVData: TCustomRVData);
var i,r,c: Integer;
    Table: TRVTableItemInfo;
    case RVData.GetItemStyle(i) of
      rvsTable:
          Table := TRVTableItemInfo(RVData.GetItem(i));
            for r := 0 to Table.RowCount-1 do
              for c := 0 to Table.ColCount-1 do
                if Table.Cells[r,c]<>nil then
                  ResetPicSize(Table.Cells[r,c].GetRVData);
      rvsPicture, rvsHotPicture:
          RVData.SetItemExtraIntProperty(i, rvepImageWidth, 0);
          RVData.SetItemExtraIntProperty(i, rvepImageHeight, 0);
Call:
      ResetPicSize(RichViewEdit1.RVData);
topcat
Post by topcat »
Thankyou for the prompt response, I will try that.
topcat
Post by topcat »
Worth every penny, Thanks!
For those wanting to use the above code ensure you have the following in your USES
CRVData, RVTable, RVItem;
