What type of data field needed
Prismax
Post by Prismax »
What type of data field is needed in a mysql database to properly save a rich edit-content?
Sorry, I do not know its name.
It must be able to contain arbitrary binary data
(or, if you set FieldFormat=rvdbRTF, it may be a memo field)
Prismax
Post by Prismax »
and where/how do I set this fieldformat?
Where do you define table structure?
Prismax
Post by Prismax »
Ok, I solved the problem. thx for the info!
