RV.clear / free
skydiablo
RV.clear / free
Post by skydiablo »
hi... (sorry for my bad english)
i have the same problem like this: http://www.trichview.com/forums/viewtopic.php?t=1037
if ein clear/free the RV, i get an error. i add some gifs, the source from the gifs are a TList -> TJvGIFImage. so i share same GIFs with the same index of the TList.
//INSERT GIF
          GIF := SmilieManager.GetSmilie(ord(sl[i][1]));
          if not Gif.Empty then
            form1.RichView1.AddPictureEx('',GIF,-1,rvvaBaseline);
//GetSmilie
function TSmilieManager.GetSmilie(index : byte) : TjvGIFImage;
  if (index < self.Count) AND (index > 0) then
    result := self[index];
  end
    result := self[0]; //ERROR Picture !!!
so i use the same source if the same GIF are used. but if i clear/free the RV, the TList items will be destroyed and ERROR! how can i fix it ?
greez & thx, sky...
The same problem, the same solution :)
          //INSERT GIF
          GIF :=  TjvGIFImage.Create;
          GIF.Assign(SmilieManager.GetSmilie(ord(sl[i][1])));
            GIF.Free;
skydiablo
Post by skydiablo »
so i cant use one instanse for all smilies ? hmmm, i need more RAM :D
i create a chat-control and if i chat with this control 10 hours, it can be many smilies !
but, thx !!!!
sky...
After calling Graphic1.Assign(Graphic2), both Graphic1 and Graphic2 use the same graphic object, so usage of memory and GDI resources are not so extensive.
