InsertText in different color of the text in richview
sergio_morisue
Post by sergio_morisue »
Sorry my english!
I use InsertText for insert one word in RichViewText, I need insert in different color in text. How i make this?
Thanks.
Please is possible one example? I'm beginner user.
function GetTextStyleWithColor(rve: TCustomRichViewEdit; Color: TColor): Integer;
var BackColor: TColor;
  BackColor := rve.Style.TextStyles[rve.CurTextStyleNo].BackColor;
  Result := rve.Style.TextStyles.FindStyleWithColor(rve.CurTextStyleNo,
    Color, BackColor);
  if Result<0 then begin
    // the style is not found, creating it
    rve.Style.TextStyles.Add;
    Result := rve.Style.TextStyles.Count-1;
    rve.Style.TextStyles[Result].Assign(rve.Style.TextStyles[rve.CurTextStyleNo]);
    rve.Style.TextStyles[Result].Color := Color;
    rve.Style.TextStyles[Result].Standard := False;
procedure InsertColoredText(rve: TCustomRichViewEdit; const Text: String; Color: TColor);
var StyleNo: Integer;
  StyleNo := rve.CurTextStyleNo;
  rve.CurTextStyleNo := GetTextStyleWithColor(rve, Color);
  rve.InsertText(Text);
  rve.CurTextStyleNo := StyleNo;
The code above uses FindStyleWithColor function. It allows finding text style with the given text and background color. The most universal style searching function is FindSuchStyle. Search "FindSuchStyle" in this forum for examples.
sergio_morisue
InsertColorText
Thanks very much!
I test the function in RichViewEdit, is perfect, insert into cursor position and search and replace, the function is all right.
But, using in DBRichViewEdit, a error ocurred: 'List index out of bounds', for DBRichViewEdit the function is different?
Can you create a simple project reproducing the problem and send it to me?
sergio_morisue
I think that found the problem
I'm using DBRichView and DBRichViewEdit in form with same RVStyle for both. This cause an error.
With one RVStyle for each, the function run correctly.
The manner to use DBRichView, DBRichViewEdit, RichView and RichViewEdit is with one RVStyle for each? This is correct?
Thanks, for help.
