Initial directory for Save-, Saveas-, Open- Dialogs
holger
Post by holger »
I want to set the Directory for Save-, Saveas-, Open- Dialogs.
How could I do this?
Thanks for any answer
Holger
Open: rvActionOpen.InitialDir property (published)
Save and SaveAs: If the opened file directory is defined, it is used. Otherwise, rvActionSaveAs.InitialDir (published)
Export: If rvActionExport.FileName (public) is empty, rvActionExport.InitialDir (published) is used. After exporting, the chosen file name (with full path) is assigned to rvActionExport.FileName, if rvActionExport.AutoUpdateFileName=True (True by default, published)
Insert Picture: The same as for export, but for rvActionInsertPicture action.
Insert File: Must be the same as for export, but for rvActionInsertFile action. But by mistake, rvActionInsertFile.InitialDir is not used. Will be fixed.
