RVPrint does not work, pls help ...
CoLT
Post by CoLT »
Some time ago i build a project and everything works fine with the rvprint.
Now, i compile the code with a new version of richview and the result is bad.
the preview works as before, but the printresult is squeezed in the top left of the page. i've tried to solve the problem without success
i load the text so richview
rv.Format;
RVPrint1.AssignSource(rv);
RVPrint1.FormatPages(rvdoAll);
Scrollbar1.Min := 1;
Scrollbar1.PageSize := 1;
Scrollbar1.Max := RVPrint1.PagesCount;
RVPP.ZoomMode := rvzmFullPage;
RVPP.First;
then i push the print button
procedure TForm1.PrintFile;
if RV.ItemCount = 0 then
PrintDialog1.MinPage := 1;
PrintDialog1.MaxPage := RVPrint1.PagesCount;
PrintDialog1.FromPage := 1;
PrintDialog1.ToPage := RVPrint1.PagesCount;
if PrintDialog1.Execute then
case PrintDialog1.PrintRange of
prAllPages:
RVPrint1.Print(form1.Caption, PrintDialog1.Copies, PrintDialog1.Collate);
prPageNums:
RVPrint1.PrintPages(PrintDialog1.FromPage, PrintDialog1.ToPage, 'EasyConcepts', PrintDialog1.Copies, PrintDialog1.Collate);
What is wrong ?
thx CoLT
Please send me a simple project reproducing this problem.
CoLT
Post by CoLT »
On my side, your project prints text starting from 2 cm from left and top edges of paper, as it is specified in rvp1.LeftMarginMM and rvp1.TopMarginMM.
CoLT
Post by CoLT »
May be the problem is in PDF printer?
