Printing Problem
cho17bee
Printing Problem
Post by cho17bee »
I am using richview version 1.9.15.1 and reportbuilder 10.
My problem basically is the following:
1) When I print the RTF (table with 2 column and some rows) using dbrichview, the report will not print some part of the row on next page if the row is longer then 1 page. which means the row did not wrap.
2) Just wonder how long do you need for the probelm, since the report is very important for my project and for my client.
Please kindly answer the question.
Look forward your reply
cho17bee
Please reply
Post by cho17bee »
I need to solve the problem as soon as possible. Please reply and help me
cho17bee
Post by cho17bee »
The issue may be a little bit hard.
but is it possible Split the row before print?.
This problem is solved in the latest version available for registered users.
But it is currently in beta stage.
