I have a TRichViewEdit with a TAB set for example at 4 cm and containing the following text
a<TAB>b
c<TAB>d
e<TAB>f
If I select this text, copy it to Clipboart (TrichViewEdit.Copy) and then paste it in WinWord the tabwidth of the first 2 lines is correct but the last line contains no TAB and uses the standard tabwidth.
This appears also at the last line of a text with less or more lines.
Is this a bug in TCustomRVData.SaveRTFToStream?
Patrik
Copy to Clipboard kills last tabulator
It is fixed in newer version (available for registered users). This new version is still beta and cannot be used for compiling release versions of applications.
Quick fix:
CRVData.pas, find the line
and change it to
Quick fix:
if (Level=0) and (StartItem<>EndItem) and IsParaStart(EndItem) and (GetItemStyle(EndItem)>=0) and (Items[EndItem]='') then
if (Level=0) then
