A better way to control spacing?
ozznixon
Post by ozznixon »
If you view the attached screenshot. I am porting a PDF into RFV (by hand).
Please notice that the right margin of the periods, is staggered. I would like to know is there a setting or a way to make this align on the right?
Re: A better way to control spacing?
Do you use tabs with a dot as a leader character? Do numbers have spaces before them?
ozznixon
Post by ozznixon »
Hey Sergey.
Right now it is just a line of period, space, period, space, etc.
The Page Numbers have a TAB before the number - that is why those line up.
Instead of using dots and spaces and tabs, you can use a single tab character.
But you need to set in the corresponding RVStyle.ParaStyles[].Tabs an item having:
- Positon = position of the page number
- Leader = '. '.
In RichViewActions, you can add tab in the paragraph dialog (or add a tab by clicking on the ruler, then set is properties in the paragraph dialog)/
But this dialog allows choosing only from a limited set of tab leaders (the same set as used in MS Word). You can define '.' (dot), but not '. ' (dot and space).
ozznixon
Post by ozznixon »
I took your suggestion - and in Paragraphs -> Tabs, leader (......) but it is still coming out a little staggered.
standay
Post by standay »
ozznixon wrote: Thu Aug 21, 2025 2:55 am I took your suggestion - and in Paragraphs -> Tabs, leader (......) but it is still coming out a little staggered.
Try 2 right-aligned tabs. First one with the leader (...) and second blank one. Play with the positioning and you might be able to make it work.
If the tab is left-aligned, a line of dot must be finished at the same position on all lines (providing that all the lines have the same paragraph style or paragraph styles with identical tab stops).
If you think it is rendered incorrectly, please send me a sample RVF file to email richviewgmailcom or attach it here.
ozznixon
Post by ozznixon »
standay wrote: Thu Aug 21, 2025 3:08 pm
You got it much closer! Changing the Paragraph -> Tabs, Right Align... Not perfect, but *much* closer!
