Using your Editor1 demo as an example. If you load the attached rtf into the editor with RTFReadProperties.SkipHiddenText set to false, the bullet does not show up, but should. I use hidden text to mark the start and end of specific text to be included in a report summary.
TRichViewFMX v23
Delphi 12.3
bullet gets hidden if hidden text not skipped
- foundations.rtf
- (1.46 KiB) Downloaded 525 times
