Data Base + HyperText
asteblev
Post by asteblev »
Hi Sergey. I have a problem when I load the data with hypertext from DB. All text and hupertext with formaing are right, but all links are corruped(OnJump: id=0; and
RichViewEdit1.GetJumpPointLocation(id, RVData, ItemNo);
  URL := PChar(RVData.GetItemTag(ItemNo));
RETURNS '';
code:
(LOAD)
procedure TSecond.RichViewEdit1Jump(Sender: TObject; id: Integer);
var URL: String;
    RVData: TCustomRVFormattedData;
    ItemNo: Integer;
  ShellExecute(0, 'open', PChar(URL), nil, nil, SW_SHOW);
Is rvoTagsArePChars included in RichViewEdit1.Options?
asteblev
Post by asteblev »
Yes, Sergey. rvoTagsArePChars is TRUE.
If this code assigns empty string to URL, this means that hypertext target was not stored in tag.
How do you insert hyperlinks?
asteblev
Post by asteblev »
  URL := PChar(RichViewEdit1.GetCurrentTag);
  URL := main.LMDInputDlg1.InputBox('','','') ;
  IF URL<>'' THEN
    BEGIN
      RichViewEdit1.ApplyTextStyle(4);
      SetURLToSelection(URL);
    END;
asteblev
Post by asteblev »
Sergey, when I use a Action Hyperlink, All is OK. What is the problem?
Probably there is something wrong with SetURLToSelection. Is it taken from the demos Demos\Delphi\Assorted\Hypertext\CreateHyperlink\ ?
As far as I remember, there was a bug in older version of this demo, it should be fixed now.
But I recommend to use the more advanced demo as a base for hyperlink creation: http://www.trichview.com/forums/viewtopic.php?t=61
asteblev
Post by asteblev »
Yes, Sergey. This Demo is OK.
