odd formatting issue - not sure of the cause.
jgkoehn
Post by jgkoehn »
Here is the good format
Sometimes it just loads like this. If the topic is reloaded it can then be fine.
Re: odd formatting issue - not sure of the cause.
Unfortunately, I can help only if I will be able to reproduce this problem.
Do you have TRVStyle linked only to this TRichView? If the same TRVStyle is linked with 2 or more TRichView, one of them can change styles in it, and others will be out of sync.
