Get if the caret is in last line, with resize
RichviewFan
Post by RichviewFan »
A Old your answer:
1) If you really mean "lines":
Code:
rve.GetCurrentLineCol(Line, Col);
InTheFirstLine := (rve.InplaceEditor=nil) and (Line=1);
InTheLastLine := (rve.InplaceEditor=nil) and (Line=rve.GetLineNo(rve.ItemCount-1, rve.GetOffsAfterItem(rve.ItemCount-1));
Lines depend on word wrapping, so when user resizes the editor window, results will be different. The method above is simple, but not very efficient. If you need to call this code often, I can give alternative version.
Dear Sergey, I really need a procedure that works also when the user resize the richviewedit.
Thank you very much.
Sorry, I do not understand the question.
The code works, it just may give different results after resizing.
You can rerun this code in OnResize event
RichviewFan
oh indeed, it works
thank you Sergey
