GetItemStyle returns value of six
tomr
Post by tomr »
Hello RichView Support,
I have pasted a hyperlink into a RichEdit control, and while debugging, I noticed something unexpected:
The ItemStyle of the hyperlink returns the value 6.
Return Value six.png (3.86 KiB) Viewed 49149 times
However, according to your documentation, the collection of text styles only goes up to number 5.
Collection of TextStyles.png (25.18 KiB) Viewed 49149 times
Am I missing something here, or is 6 (perhaps rvsJump) a predefined style outside of the user-defined collection?
Thank you in advance for your clarification!
Best regards
Tom
Re: GetItemStyle returns value of six
The values in this table are indexes of initial styles. These styles are added to TRVStyle.TextStyles by default, but you can add and delete them.
While editing (including insertion from a file or the clipboard), new styles can be added. Editing operation do not delete styles, but they can add new styles.
For a text formatting that already exists in TRVStyle.TextStyle, the editor re-uses existing items.
But if the inserted file contains a text formatting that do not exist in TRVStyle, the editor may add a new item to represent it.
Style handling options on insertion depend on the format of the inserted file.
RichView Format (RVF)
Depending on RVFTextStylesReadMode property, the component cn:
- add new styles, or
- use the most similar existing styles,
- ignore text properties and use indexes of styles
RTF and DocX
Depending on RTFReadProperties.TextStyleMode property, the component can
- use the style with the specified index
HTML and Markdown
The editor always adds new styles when necessary.
Similar properties exist for paragraph styles.
