I am using the trial version under Delphi 12.3
I am using the OnDrawStyleText event to colorize different types of hyperlinks. They all have underlines, some are grayed out, one type is blue and some I highlight with light yellow.
With out resizing the form in the example attached, loading foundations.rtf shows that the first hyperlink is blue as expected, but not underlined (but should be). Note that the same Foundation types hyperlink section was simply duplicated after the table, and that copy is both blue and underlined as it should be. The rest of the RTF text is colored properly unless I scroll up a bit, then suddenly all the lines are missing, but everything else is still properly colored (except the first hyperlink mentioned earlier). So the coordinates are not the problem.
I'm not sure why this is happening with the lines only. I've attached a modified version of your Editor 1 demo. Use it to load foundations.rtf
Thoughts?
Eric
DrawStyleText DrawLine issue
- Editor 1 modified.zip
- (83.31 KiB) Downloaded 852 times
- Missing top line only.png (36.36 KiB) Viewed 69266 times
- Missing all lines.png (34.31 KiB) Viewed 69266 times
Re: DrawStyleText DrawLine issue
What's your code in OnDrawStyleText?
It's in the "Editor 1 modified.zip" file I provided so you can view the code and test. Are you not able to access or open that attachment?
I solved the underline disappearing issue. I had to create a TStrokeBrush, and pass that as a parameter to Canvas.Canvas.DrawLine rather than using Canvas.Canvas.Stroke.Color (which I no longer need).
