Hi there,
I would like to convert a RTF data in TEXT data avoiding the format characters.
Is it possible ? How can I do that ?
Marco
Convertion from RTF to TEXT.
For example,
Using:
function SaveTextToField(rv: TCustomRichView; tbl: TTable;
const FieldName: String): Boolean;
var Stream: TStream;
Result := rv.SaveTextToStream('', Stream, 60, False, False);
Stream.Position := 0;
TBlobField(tbl.FieldByName(FieldName)).LoadFromStream(Stream);
Stream.Free;
Table1.Edit;
SaveTextToField(RichViewEdit1, Table1, 'TextField');
Table1.Post;
I tried your suggestion and the text has been saved in the data field. However, some characters have been changed after the process.
e.g.
The original text:
When saving text in text file the problem does not happen.
Do you have any idea how I could solve that ?
Marco
e.g.
The original text:
The text after saved in the data field:artigo 20, inciso III, alínea “b”, da Lei Complementar nº 11/91
See the “ character has been changed by ¿ character .artigo 20, inciso III, alínea ¿b¿, da Lei Complementar nº 11/91
Marco
