Tab Key Behavior with Bulleted Lists in TRichViewEdit
tomr
Post by tomr »
Hello Richview-Support,
I have the following question: Is it possible to indent bullet points with a tab in TRichview?
In my Richviewedit i have these bullet points
BulletPoints Ausgangssituation.png (1.19 KiB) Viewed 33667 times
If I press tab, only the text moves.+
BulletPoints Verschoben.png (1.54 KiB) Viewed 33667 times
In Word, the next indent will be triggered.
BulletPoints Word.png (2.66 KiB) Viewed 33667 times
Kind Regards
Tom
standay
Re: Tab Key Behavior with Bulleted Lists in TRichViewEdit
Post by standay »
I use the TrvActionIndentDec (action for "Decrease Indent" command) and TrvActionIndentInc (action for "Increase Indent" command) actions. I have those assigned to some toolbar buttons.
I also put this into the rveKeyPress event so I can select some text and move it in or out using tab/shift+tab like the Delphi IDE:
  if Key=#9 then
    if rve.SelectionExists then
      Key := #0;
      //Shift + Tab when text selected (remove tabs):
      if (GetKeyState( VK_SHIFT ) and $8000 <> 0) then
        RVEParagraphrvActionIndentDec1.ExecuteTarget(rve);
      end
      else //Tab when text selected (add tabs)
        RVEParagraphrvActionIndentInc1.ExecuteTarget(rve);
Sergey may have some other answer(s) but that's what I use. It works on bulleted text.
