Table save in rtf-Format...
Crowbar
Post by Crowbar »
i have following problem:
1.
load rtf-File with table in the RichViewEdit
2.
change the border-width of table from 1 (or higher) to 0 (no border)
3.
save the rtf-File
4.
load rtf-File again and i would like the border-width to change from 0 (no border) to 1 (or higher)
But after save and again load of rtf-File, I can not more change the border-width of table. => border-width = 0 (no border) forever :?
With rvf-File works correct.
Give it a solution for this?
Regards
Crowbar
Tables in HTML are designed by HTML model.
Tables in RTF are different, so conversion is performed (sometimes it's very complicated). It's not always possible to keep all properties of table when saving and loading from RTF.
After loading such tables from RTF, all table.VisibleBorders are set to False (RichViewActions do not allow to change table.VisibleBorders yet)
