Copy RichView content to another RichView - Table style problem
mwsta
Post by mwsta »
I'm trying to copy the content of one richview to another one using this code:
TMemoryStream *stream = new TMemoryStream();
source->SaveRTFToStream(stream, false);
stream->Position = 0;
target->LoadRTFFromStream(stream);
target->AddNL("", 0, 0, RVEMPTYTAG);
target->Format();
delete stream;
However, the tables look different in the original (source_richview.jpg) compared to the new RichView (target_richview.jpg). What am I missing? How do I need to transfer the table styles?
mwsta
Re: Copy RichView content to another RichView - Table style problem
Post by mwsta »
Related to the problem above is the following: I also want to copy the content of a TRichView into a TSRichView->RichViewEdit, but it seems the styles are not copied. I tried to assign them manually using:
ReportSRichViewEdit->ExternalRVStyle=my_rvstyle;
where my_rvstyle is a pointer to a TRVStyle object). That didn't work. I also tried:
ReportSRichViewEdit->RichViewEdit->Style=my_rvstyle;
but it didn't work either. Clearing the styles before:
ReportSRichViewEdit->RichViewEdit->Style->TextStyles->Clear();
ReportSRichViewEdit->RichViewEdit->Style->ParaStyles->Clear();
didn't help. What is the correct way to do this?
Not all table properties can be saved to RTF.
Use SaveRVFToStream and LoadRVFToStream.
