Loading RichView with Footer?
Crowbar
Post by Crowbar »
i would like to loading the content of Printpreview (with Footer) in the RichView.
That's ok, but why will be loading the Richview without Footer?
It is possibly the total content of Printpreview (with Footer) to loading in the RichView?
Var
 ms : TMemoryStream;
  ms:=TMemoryStream.Create;
   PVPrintPreview.RVPrint.SavePageAsRVF(ms,1);
   ms.Position:=0;
   RichView1.Clear;
   RichView1.LoadRVFFromStream(ms);
   RichView1.Format;
   ms.Free
Regards
Crowbar
Is your footer a formatted document (in RVF format), or a plain text?
Crowbar
Post by Crowbar »
my footer is a formated document (in RVF format).
RVPrint1.SetFooter(FootRichViewEdit.RVData);
Current version does not allow saving multiple documents in one RVF file.
You need to implement it yourself.
Possible solution:
- invent you own file format containing several RVF documents
- save the footer document in the DocProperties property of the main document.
DocProperties is a collection of text strings. Line break characters are allowed, but binary content is not. So you need to exclude rvfoSaveBinary from FootRichViewEdit.RVFOptions. After that, you can save it content to TStringStream and add its string to DocProperties.
Crowbar
Post by Crowbar »
is planned in the future of version, that the function "PVPrintPreview.RVPrint.SavePageAsRVF" save all ... with the "Footer" (and "Header") too?
Regards
Crowbar
Probably
