How to support unicode for multiline text
uniandy
Post by uniandy »
Hi Sergey-
Do you have any updates for the exampe:
http://www.trichview.com/support/files/script2.zip
in the main unit, you said:
- supporting Unicode text (some modifications in InsertMultilineText are Not implemented
I tried your example, and it really cannot support multi text unicode, this is the snapshot:
the A part is the original 2-line text and the B part is the result, I tried to solve the problem but haven't find any solution so far, do you have any better solutions on how to change InsertMultilineText menthod to support unicode for multiline text?
uniandy
Post by uniandy »
procedure InsertMultilineText(RVData: TCustomRVData; var ItemNo, Pos: Integer; const Value: String);
item: TRVTextItemInfo;
s1, s2: String;
sl: TStringList;
i: Integer;
if Value='' then exit;
s1 := RVData.GetItemTextA(ItemNo);
s2 := Copy(s1, Pos, Length(s1));
s1 := Copy(s1, 1, Pos-1);
sl := TStringList.Create;
sl.Text := Value;
// workaround - TStringList ignores the last cr lf
if (Length(Value)>1) and (Value[Length(Value)-1]=#13) and (Value[Length(Value)]=#10) then
sl.Add('');
// end of workaround
if sl.Count=1 then begin // if it's a single line, then do this
RVData.SetItemTextA(ItemNo, s1+Value+s2);
sl.Free;
inc(Pos, Length(Value)-1);
exit; // exit when this is done
RVData.SetItemTextA(ItemNo, s1+sl[0]);
// for multi-line, maybe this is whether the non-unicode is caused
for i := 1 to sl.Count-1 do begin
item := RichViewTextItemClass.Create(RVData);
s1 := sl;
if i=sl.Count-1 then s1 := s1+s2;
item.StyleNo := RVData.GetItemStyle(ItemNo);
item.ParaNo := RVData.GetItemPara(ItemNo);
item.Inserting(RVData, s1, False);
RVData.Items.InsertObject(ItemNo+i, s1, item);
item.Inserted(RVData, ItemNo+i);
ItemNo := ItemNo+sl.Count-1;
Pos := Length(sl[sl.Count-1])+1;
sl.Free;
uniandy
Post by uniandy »
Hi,Sergey-
Can you help me to solve this problem? I cannot find any solution on this...
Many thanks
I'll modify this example later this week.
uniandy
Post by uniandy »
Ha, it's been a long time from last visit from this community. it's so happy that I can visit this site again use a Germany web agent. :D
uniandy
Post by uniandy »
Hi,Sergey-
Any updates for this functionality?
best wishes
Oops, sorry.
Done. Not only modifications to support Unicode in this demo, but also a completely Unicode version.
See here: http://www.trichview.com/forums/viewtopic.php?t=9#5883
uniandy
Post by uniandy »
Sergey-
Thanks a lot, you are great and cool!
This is perfect !!!
