IDEInstaller v2.5
IDEInstaller v2.5
We've released our installer program as freeware with source code:
http://www.trichview.com/ideinstall/
It was updated to version 2.5.
This utility can be used by Delphi component developers to install their packages in Delphi and C++Builder IDE (from Delphi 5 and C++Builder 6 to RAD Studio 12 Athens). Both source code packages and trial packages are supported.
It makes some assumptions about package names and directory structure (the installer includes a help file describing them in detail). We have a utility that can generate Delphi and C++Builder packages for any components, VCL and FMX. This utility is for internal use, but if you provide a list of units, dcr files and required packages, I can generate packages for all version of Delphi and C++Builder for your components, for free.
Changes:
  • Support for 64-bit IDE (for RAD Studio 12.3+)
  • New application icon (to make it distinct from the icon used in TRichView setups)
This new IDE installer is already used in the last versions of our setups.
Previous version
viewtopic.php?t=13665
