OnJump -> OnRVDblClick
Fab85
Post by Fab85 »
Open link using Onjump event work fine.
But on my old application with TrichEdit I handle OnDblClick event to open link (so without CTRL pressed). So I need to do the same with TrichViewEdit.
So I try to do the same with :
procedure MyTRichView.OnTRichViewEditRVDblClick(Sender: TCustomRichView;  ClickedWord: TRVUnicodeString; Style: Integer);
  LRVData:        TCustomRVFormattedData;
  LItemNo, LOffs: Integer;
  LLink:            String;
  pt:             TPoint;
  if not assigned(Sender) then
   LGlobalMousePos := Mouse.CursorPos;
   LLocalMousePos := (Sender as TControl).ScreenToClient(LGlobalMousePos);
   pt := Sender.ClientToDocument(Point(LLocalMousePos.X, LLocalMousePos.Y));
  if Sender.GetItemAt(pt.X, pt.Y, LRVData, LItemNo, LOffs, True) and
    LRVData.GetItem(LItemNo).GetBoolValueEx(rvbpJump, Sender.Style) then // Doesn't work for hyperlink/jump
    LLLink := LRVData.GetItemTag(LItemNo);
    OpenUrl(LLLink);
But if the end-user click on a hyperlink (= which call the onjump event is CTRL is down) the condition :
Always return false
So how to detect the url clicked in a OnRVDblClick event ?
Re: OnJump -> OnRVDblClick
Sorry, but I cannot reproduce this problem.
I copied your code in the ActionTestTabs demo, and this code works, both for links in the root document and for links in table cells.
Can you give me step-by-step instructions how to reproduce the problem?
