Empty after html content pasted from clipboard ?
Fab85
Post by Fab85 »
To test is a TRichViewEdit is empty.
Equivalent of a :
if (trim(MyTRichEdit.Lines.text)='') then ...
I use this function :
// look for an equivalent to
function IsRichViewEmpty(ARichView: TCustomRichView): Boolean;
  LIndex: Integer;
  Result := True;
      for LIndex := 0 to ARichView.ItemCount - 1 do
        if (ARichView.GetItemText(LIndex) <> '')   then
          Result := False;
          Exit;
  except
It's the good way to do or not ?
Because sometime if the end-user copy an HTML content, select all content of the TRichViewEdit destination , and paste the HTML content (Using CTRL + V or popup with native action), my function seems to return true ?
Something is missing like a validation / post before check if it is empty ?
Re: Empty after html content pasted from clipboard ?
Your code will returns True if ARichView contains multiple lines (because it does not check the item count) or if it contains an image without an assigned name (because it does not check GetItemSyle)
Use
  Result := (ARichView.ItemCount = 0) or
   ((ARichView.ItemCount = 1) and (ARichView.GetIemStyle(0) >= 0) and (ARichView.GetIemText(0) = ''));
This function returns True of ARichView does not have items, or it has a single empty text item.
Fab85
Post by Fab85 »
Thank you for your source code it's work fine.
