What did i miss here?
RichViewEdit1.Clear;
RvHtmlImporter1.LoadHtml(memo1.Text);
RichViewEdit1.Format;
Im trying to load an HTML from a string or memo1 to RichViewEdit1 but it doesnt display the correct formatting.
Need help in Loading HTML using RVHtmlImporter
Re: Need help in Loading HTML using RVHtmlImporter
RvHtmlImporter1 is an obsolete component; it supports only basic HTML formatting.
Use this code:
Use this code:
Stream: TStringStream.
Stream:=TStringStream.Create(memo1.Text, TEncoding.UTF8);
RichViewEdit1.LoadHTMLFromStream(Stream, '', CP_UTF8);
Stream.Free;
Thank you so much sir! Perfect!
