emoji icon
standay
emoji icon
Post by standay »
I found the following in an old forum post:
For example, you can type 1F43B, press Alt+X, and it will be converted to 🐻 (your browser may convert this character to emoji icon; TRichView does not do it)
Alt + X works fine, but a regular trichview shows a b/w character. Is there any way to do some delphi code to convert 1F43B into a color emoji icon? Just wondering about this and thought I'd ask. Both windows apps notepad and VS Code seem to do this on the fly.
Re: emoji icon
Text engines used by VCL version of TRichView do not support colored emoticons. FireMonkey version does.
