Replay...
cleytonmaiabr
Replay...
Post by cleytonmaiabr »
Hello, is it possible to create a replay routine? For example, I wanted to record something, and when I clicked a button it would give me a replay from 30 seconds ago. Would that be possible?
cleytonmaiabr
Re: Replay...
If it's possible to make a 30-second delay in the video, that would also solve the problem.
Re: Replay...
Do you want to play the last 30 seconds of the recorder file when the recording is stopped?
Unfortunately, RVCamera does not support positioning yet, it can play files only from the beginning.
cleytonmaiabr
Re: Replay...
So there's no way to make the camera lag behind in filming? Like a 30s delay?
