FFmpeg not found
TimR
FFmpeg not found
Post by TimR »
Hi, I am evaluating RVMedia. I downloaded the compiled demo projects. I am testing the IPCamera.exe application.
I downloaded the FFmpeg dll files from the link in the post "FFmpeg libraries for Windows".
I copied the 7 dll files into the same folder as IPCamera.exe and tried running it. It displays "FFmpeg is not found. RTSP and H.264 are not supported."
I'm not sure whether the compiled file is 32-bit or 64-bit but I tried with both versions of the dll files and the result is the same.
Can you please explain what else I need to do to get the demo working?
Thank you.
Re: FFmpeg not found
The compiled demo projects from https://www.trichview.com/download/mediademo.html already include FFmpeg DLLs for 64-bit Windows.
If installed in c:\Components\RVMedia, then:
FFmpeg is in c:\Components\RVMedia\CompiledDemos\ThirdParty\FFmpeg\Win64\bin\
The IPCamera demo is in c:\Components\RVMedia\CompiledDemos\Demos\Delphi\Cameras\IPCamera\
If you open the source code of this demo, you will see the code:
{$IFDEF WIN64}
initialization
  LoadFFMpegLibraries('..\..\..\..\ThirdParty\FFmpeg\Win64\bin\');
{$ENDIF}
So,
1) The compiled version of this demo requires 64-bit versions of FFmpeg DLLs
2) It ignores DLLs in its own folder, and looks for DLLs in '..\..\..\..\ThirdParty\FFmpeg\Win64\bin\'.
If ran from the original folder, this demo must work just out of the box.
TimR
Post by TimR »
Thanks for your reply. I understand and it's working well now.
