TRichView and ReportBuilder 23
TRichView can be used to add advanced rich text objects to ReportBuilder reports.
ReportBuilder v23 has been released recently.
The existing TRichView+RB code is compatible with ReportBuilder v23, with one exception: PDF export. An access violation error occurs when you attempt to export a PDF file containing TRichView objects.
PDF export in ReportBuilder v23 was optimized, but this optimization was not compatible with some third-party add-ons, including ours.
Digital Metaphors has a patch fixing this problem, you can request it from them.
It will be included in the next update of ReportBuilder.
