TrichViewEdit : ChangeSelectedTextColor best code ?
Fab85
Post by Fab85 »
I'am always studying the TrichViewEdit component.
I have find two way to change by code (without using Taction) the text color of the selected text.
Which is the better one ? Maybe it's exists a better way ?
procedure ChangeSelectedTextColor(ARichViewEditTarget: TCustomRichViewEdit; AColor: TColor);
  LNewStyleNo, LExistingStyleNo: Integer;
  LStyle: TFontInfo;
  LRVStyle: TRVStyle;
  if not ARichViewEditTarget.CanChange then Exit;
   LRVStyle := ARichViewEditTarget.Style;
   LNewStyleNo := LRVStyle.TextStyles.Count;
    LStyle:=LRVStyle.TextStyles.Add;
    LStyle.Assign(LRVStyle.TextStyles[ARichViewEditTarget.CurTextStyleNo]);
    LStyle.Color := AColor;
   ARichViewEditTarget.ApplyTextStyle(LNewStyleNo);
  LStyle: TFontInfo;
  LRVStyle: TRVStyle;
   LStyle := TFontInfo.Create(nil);
      LRVStyle.TextStyles.Add.Assign(LStyle);
      LStyle.Free;
Re: TrichViewEdit : ChangeSelectedTextColor best code ?
ApplyTextStyle applies the same font attributes to the selection (including font name, size, etc.).
If you want to change only one property (such as a text color) and do not want to change other properties, you need to use ApplyStyleConversion method and OnStyleConversion event.
See the demo in Demos\DelphiUnicode\Editors\Editor 2\
First, the demo defines integer constants for each operation, including the operation of changing text color:
TEXT_COLOR         = 7;
Next, it uses cd: TColorDialog to request a color from user and call ApplyStyleConversion:
  cd.Color := rvs.TextStyles[rve.CurTextStyleNo].Color;
  if cd.Execute then
    rve.ApplyStyleConversion(TEXT_COLOR);
(in this code, rve is TRichViewEdit, rvs is TRVStyle)
OnStyleConversion (I removed code for other operations):
procedure TForm1.rveStyleConversion(Sender: TCustomRichViewEdit;
  StyleNo, UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
  FontInfo: TFontInfo;
  FontInfo := TFontInfo.Create(nil);
    FontInfo.Assign(rvs.TextStyles[StyleNo]);
    case UserData of
      TEXT_COLOR:
        FontInfo.Color := cd.Color;
    NewStyleNo := rvs.FindTextStyle(FontInfo);
    FontInfo.Free;
Fab85
Post by Fab85 »
That's a bit complicated on my scenario :
I have a lot of TrichViewEdit (or TcxTRichViewEdit) on different forms. So a TDI application.
Each connected to a TRVStyle. TcxTRichViewEdit seems to automagically create him TRVStyle.
In a common TDataModule I have a TPopupMemu. All my TcxTrichViewEdit show this common TpopupMenu.
This TPopupMenu contains a Menu item to change color of the user connected in one click (I don't want a dialog box to select color).
So I need to Handle a OnStyleConversion event of each of my TRVStyle ?
Currently, there are only two ways to apply changes to selected text: (1) using TrvActionFontEx from RichViewActions (2) using ApplyStyleConversion method + OnStyleConversion event.
I plan to add a new component soon to simplify editing operations without using actions, but it is not ready yet.
OnStyleConversion is an event of TRichViewEdit, not of TRVStyle.
When using TcxTRichViewEdit, assign cxTRichViewEdit.Properties.OnStyleConversion.
One of possible solution is assigning this event temporarily when doing the operation.
You need two methods:
1)
procedure TForm1.ColorStyleConversion(Sender: TCustomRichViewEdit;
  FontInfo.Color := TColor(UserData);
  FontInfo.Free;
procedure TForm1.ChangeColor(cxRVE: TcxTRichViewEdit; Color: TColor);
  OldEvent: TRVStyleConversionEvent;
  OldEvent := cxRVE.Properties.OnStyleConversion;
  cxRVE.InnerEditor.ApplyStyleConversion
  cxRVE.Properties.OnStyleConversion := ColorStyleConversion;
  cxRVE.InnerEditor.ApplyStyleConversion(Integer(Color));
  cxRVE.Properties.OnStyleConversion := OldEvent;
