Does RichViewEdit had some property to get it's plain text?
gcw5zb
Post by gcw5zb »
Does it had?I can get the text ,but is there any simple way like "richedit.text"?
s := GetAllText(rv); // function from RVGetText unit
alanmcd
Post by alanmcd »
If I just do this from a form
  sItemDes: String;
          sItemDes := GetAllText(frmeMEItemList1.DBRichViewEdit1);
          Showmessage(sItemDes);
I see the text excluding format codes which is what I want.
But if I do this via code:
            LoadRVFFromField(rvHidden, SchoolDB.IB_QItemListExport, 'RVDESCRIPTION');
          sItemDes := GetAllText(rvHidden);
where LoadRVFFromField is as you have it above, I get an empty string.
What might be the issue with this?
Alan
The only reason I can imagine is that LoadRVFFromField fails for some reason, or the field is empty.
alanmcd
Post by alanmcd »
The field has a value - I can showmessage the value.
The function is:
function TMEProjectSelect.LoadRVFFromField(rv: TCustomRichView; qry: TIB_Query;
                          const FieldName: String): Boolean;
var Stream: TStream;
  Stream := qry.CreateBlobStream(qry.FieldByName(FieldName), bsmRead);
    Result := rv.LoadRVFFromStream(Stream);
    Stream.Free;
alanmcd
Post by alanmcd »
sorry - should have been LoadRTFFromStream
Alan
