TrichRichViewEdit.GetWordUnderCursorWithDelimiters ?
Fab85
Post by Fab85 »
I need to extract a selected word delimited by text (start delimiter '[' end delimiter ']'), for example:
"Sample data speed: [CustomerTable.MyField] km/h".
I want to display a "friendly" caption of the selected delimited field.
If a letter of MyField is selected, TrichRichViewEdit.GetCurrentWord will return 'MyField', but I need to get 'CustomerTable.MyField'.
I was thinking of removing '[', ']', '.' from TCustomRichView.delimiters before calling TrichRichViewEdit.GetCurrentWord, but this approach seems to be above all since I am using TrichRichViewEdit.OnSelect event.
I haven't found a solution in the Trichview documentation, so I have come up with the following code.
Unfortunately, it does not work in some cases. Do you have a better solution?
function GetWordUnderCursorWithDelimiters(  ARichView: TRichViewEdit;   APrefix, ASuffix: string  ): string;
  LItemIndex, LOffset, LStartPos, LEndPos: Integer;
  LText: string;
  Result := '';
  // Get index of item focused
  LItemIndex := ARichView.CurItemNo;
  LOffset := ARichView.OffsetInCurItem;
  // Check active item
  if (LItemIndex >= 0) and (ARichView.GetItemStyle(LItemIndex) >= 0) then
    // get texy
    LText := ARichView.GetItemText(LItemIndex);
    // find start delimiter
    LStartPos := LOffset;
    while (LStartPos > 1) and (Copy(LText, LStartPos - Length(APrefix), Length(APrefix)) <> APrefix) do
      Dec(LStartPos);
    // find end delimiter
    LEndPos := LOffset;
    while (LEndPos <= Length(LText)) and (Copy(LText, LEndPos, Length(ASuffix)) <> ASuffix) do
      Inc(LEndPos);
    // Adjust position to exclude delimiters
    if (Copy(LText, LStartPos - Length(APrefix), Length(APrefix)) = APrefix) and
       (Copy(LText, LEndPos, Length(ASuffix)) = ASuffix) then
      // Exclure le préfixe et le suffixe de l'extraction
      Result := Copy(LText, LStartPos, LEndPos - LStartPos);
Re: TrichRichViewEdit.GetWordUnderCursorWithDelimiters ?
I think your code is correct.
I'd add the following line at the beginning, to allow working with text in table cells:
  ARichView := ARichView.TopLevelEditor as TRichViewEdit;
This code will not work if you need text belonging to multiple items ('[' in one text item, ']' in another text item). Otherwise, it must be ok.
