TRichViewEdit LoadRTFFromStream add an empty line
Fab85
Post by Fab85 »
I am testing TRichViewEdit, and I encountered an issue where it seems to add an unwanted line break at the first line. Below is the code I used for testing:
procedure TForm17.FormShow(Sender: TObject);
  LTextString:TStringstream;
   LTextString:= TStringstream.create;
    LTextString.WriteString(
        '{\rtf1\ansi\ansicpg1252\deff0\nouicompat\deflang1036{\fonttbl{\f0\fnil\fcharset0 Calibri;}}'
        +'{\*\generator Riched20 10.0.22621}\viewkind4\uc1'
        +'\pard\sa200\sl276\slmult1\f0\fs22\lang12 Line 1\par'
      LTextString.Position:=0;
      RichViewEdit1.LoadRTFFromStream(LTextString);
      RichViewEdit1.ReformatAll;  // same with RichViewEdit1.Reformat
      LTextString.free;
My RichViewEdit1 component is a default TRichViewEdit, and no properties were modified. However, when loading the RTF content, a line jump is added at the beginning of the text.
I am attaching a screenshot and the full source code for reference.
Environment:
Delphi 11.3 and 12.2 VCL
TRichView version 23
Could you please let me know why this happens and how to resolve it?
LineJump.zip
(12.27 KiB) Downloaded 5980 times
Re: TRichViewEdit LoadRTFFromStream add an empty line
Formatted TRichViewEdit control initially contains one empty text line.
LoadRTFFromStream does not clear document before loading, it appends content to the end.
Just call Clear before LoadRTFFromStream.
Fab85
Post by Fab85 »
Hello Sergey,
I fell into the trap because, in most cases, a LoadFromStream (Tmemo, Trichedit) operation clears the destination content. However, you clearly mentioned this in the documentation, and I missed it :roll: .
Thank you for your quick and efficient response—it’s greatly appreciated!
