FFmpeg not working
Wneku
FFmpeg not working
Post by Wneku »
I try to use RVMedia to display RTSP stream from camera.
When using example in Demos folder with my RTSP URL it's working fine.
In my project I added TRVCamView and TRVCamera, same as in example, I double checked and all settings for TRVCamera look the same, FFmpeg is copied in my project folder and I try to use
__fastcall TForm1::TForm1(TComponent* Owner)
	: TForm(Owner)
#ifdef _WIN64
  	LoadFFMpegLibraries("FFmpeg\\Win64\\bin\\");
#endif
Just like in demo (I tried different paths, including absolute, so it's not issue with path), and still
RVCamera1->IsSupportedFFMPEG()
returns false. I don't see anything different between what I did and Demo project, where it works.
Any suggestions, ideas? Is there some obscure setting to make ffmpeg working?
Thanks in advance for any help!
Re: FFmpeg not working
There are no other settings.
I can imagine only the following reasons:
- the path is not correct
- FFmpeg version is not supported by RVMedia (RVMedia 11 supports FFmpeg up to version 7.x; RVMedia 10.2 up to version 6.x; 10.0 up to version 5.x)
- application bitness is different from FFmpeg.
Unfortunately, the only way to understand why it is not loaded is debugging source code of LoadFFMpegLibraries step by step.
